i've got a weber 2brl 32/36 DGV on mine. po had it mounted w/ the linkage on the fire wall side and so jerry rigged that the thing ran on both barrels all the time. i rotated it 90 degrees clockwise and fiddle with the linkage angles until the full movement of the pedal tranlated to the full movement of the trottle lever. just as jerry rigged but i now have an idle of 750 rpms and i can move through the gears without kick'n in the 2nd barrel unless i want to.
'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
