I bought an Atlantic British parabolic suspension kit and had my shop install it in the place of the completely worn out shocks and springs on my SIII 109. The rear springs were so bad they were bending in an "s" shape in the wrong direction....
The new suspension looks great, but when I went to pick it up from the shop, I immediately noticed a womp womp womp vibration when I let off the accelerator. After turning right back around and heading back to the shop, we figured out that the new springs changed the rear drive shaft angle so much that the clearance between the shaft and the hole in the cross member is minimal, and a balancing weight on the shaft is hitting the cross member. It doesn't help that the u-joint is also worn out.
It looks like the mounts for the transfer case are worn out, and replacing these might give me just the lift I need to clear the cross member, in addition to a new u-joint and either balancing the drive shaft to eliminate the weight, or replacing it all together.
So here's the question, are the transmission mounts that are available interchangeable and/or the same as the mounts above the transfer case? I can't find any transfer case mounts listed, and since the transmission and transfer case are mated, I'm hoping that they are one in the same.
