Not all that handy, but a good listener....
1961 Ser IIa Hybrid Defender
1969 Ser IIa Bugeye
1980 Ser III Lightweight 24V RHD- sold
1988 LR90 turbo diesel RHD - currently frame off rebuild in progress
1998 Disco - ex wife :-(
2000 Disco - RIP , end over end 2.5 times
2010 RR Sport Supercharged
http://mikerovers.shutterfly.com/
Most may have seen this one, it was a while back... but still makes me smile and reminds me why I love the old oil dripper...
http://www.youtube.com/watch?v=eCfCD...feature=colike
thanks PhilipJohnBrooks... great talent.
mike
1969 Ser IIa Bugeye
Here are the pictures from the snorkel. Let me know if you'd like more pictures. The point where it connects to the carburetor seems a bit "rigged" as it doesn't fit very tightly. I might try to figure something else out.
My air cleaner to webber carb was a bit loose also. It was attached with a rubber plumbing adapter for 1" to 1 1/2" piping. The adapter was very dry and hard, and would not flex to conform to the carb throat anymore. I went down to the local hardware store, and picked up a new one. $2.00, and about 5 minutes worth of work, and it is sealed nicely. I don't know if this is how others have sealed their's, but it was how mine was set up.
is the a modified air cleaner or ones of the original inlet/outlet ones?
I’m jealous
1971 SIIa 88" NAS Dauntles V6
1974 SIII 109" RHD
There is a metal ring at the top of the Weber 34ICH that tends to become loose over time. Remove it, clean everything thoroughly, then epoxy it back in place with JB Weld or PC-7 epoxy. JB Weld works a little better in this application because it is a thinner consistency.
where can one find the "non-vented" oil bath cover?
Here is part of my Series on the way back from Saquish Mass
Best,
Mark
__________________
1965 Series IIa
I would love the one pictured as well..
I did some research last night and there is a company that makes oil bath filters similar with an inlet and outlet..
Monday I will look into sizes and air flow specs..
I am more determined than ever right now to find a factory look alike, oil bath or paper filter canister that I can use for a raised air intake..
1974 SIII 109" RHD
