Trying to get my new MOD 110 street legal and can't seem to get the brake lights and turn signals to work. I'm also a little confused about the 6 position light switch. I assume the brake lights and turn signals should work even with the light switch in the off position, but I don't get any voltage at the fuse panel. Where is the turn signal flasher relay? I noticed in the owners manual that the alternator indicator lamp in the instrument cluster is wired in series, and if the bulb is burned out, then the battery will not charge. Are the turn signals and brake lights wired the same way? I guess for normal street use the correct position for the light switch is HST? In the rear of the vehicle I have 2 sets of amber lights and one pair of red lights. One of the amber lights work, are these the convoy lights? Sorry to ramble, I realize there's about 6 questions in here, appreciate any guidance.
