I've replaced this recently for this same reason (squealing right after starting
and the first ten minutes or so of warm up).
Replacing it with a new one cured it but it has now come back after a couple of hundred miles. I've tried belt dressing but that will only help for a very short time. The noise seems centered on the fan clutch/water pump pulley.
There is no coolant dripping out the weep hole in the water pump so I don't think that could be the problem. Any ideas?
