Ok folks, I need help getting turn signals to work on 12v MOD 110. After today I have brake lights, and front/rear "Running lights" working. Also, when 4 way flasher used, what I expect to be turn the signals flash. So I have power to all 6 rear and 4 front lights. I have studied the wiring diagram for hours and the only relay for the turn signals appears to be the same as the 4 way flasher relay (Behind the fuse panel). Is there a separate relay for the turn signals? if so where is it? Soooo close to getting it registerd!
Thanks,
Geoff
