Results 1 to 8 of 8
Thread: LED Light conversion
    Default LED Light conversion
    Hey guys just starting to gather some information on converting my rear lights and possible the front turn indicators to LED's. I found ECR's conversion kit but don't feel like spending the $$$ for something so simple. Anyone know where to find LED's that will fit our D-90s?
    Mac Mattingly
    St. Simons Island, Ga
    Ebay. Just look for led bulbs, but to be honest I find the coloured glass bulbs are better. The led bulbs are very bright but very small. The glass bulbs spread the light over a bigger area. Just replace the lens with a clear side light lens.
    Quote Originally Posted by Maxredd90
    The lights are available direct from the supplier. Mike from ECR was gracious enough to post the manufacturer's name.
    The problem isn't the base, bulb, or case. It's properly wiring it as ECR does. They pre-wire everything do that it actually works as intended and uses plug and play wiring. It's not as easy as you first suspect. The flashers are difficult to sort out.
    Search D-90.com for the thread. Post up and see if anyone is interested in a group buy. Mike helped out a lot of folks the last time.
    Oct 2008
    San Antonio, TX
    101
    Default LED Tail lights
    Checked out the LED tail lights on my recent 110 MOD purchase and found the following:
    Trucklite modle 10
    Jamestown, NY
    I got the vehicle to pass inspection Sat, so thats something! Not too impressed with the connections/water proofing etc, but if you google them, they are about $8-$12 which seems reasonable.
    Hope that helps.
    The LED versions are not fully sealed by the way. Mine still see to fill with water when it rains.
    Jan 2007
    11
    Just FYI the LED tail lamps we sell for 95-97 NAS D90s are fully sealed. I have had one in a bucket for the last few weeks as a test. No leaks, still working. Others brands may leak, but not ours.
    Thanks!!
    My son bought a cheap LED light to experiment with a few months ago. One of the things he did was put the light in water and then freeze it. It has been in the freezer for two months and still works inside a block of ice. Aren't LED's in and of themselves sealed? I dont think water would affect the bulb but may affect the wiring.
