Shuttle Valve
I have a 99 Disco II and have been dealing with the 3 "amigo" lights for some time. Most of the time they will reset themselves when you turn the car on and off and I have done some playing with what still works when they are lit....my ABS seems to function but not the traction control which seems to be the culprit when they all come on. I understand that using anything other than factory Land Rover pads and rotors will cause issues with this but when my light come on and stay on due to a "hard" fault it refers to the ABS Shuttle valve which is part of the ABS pump/modulator which is a $2300 part. We live in Arizona so it is generally not an issue but we travel to snowy locations and I like to know I have working ABS and TC. I am curious to see any other advise or thoughts relating to this problem.
Detroitdozer
99 Discovery II
94 Defender 90
