I've heard on the Discoweb boards you can use rear springs on a DI and add 2in pucks to the rear to get a 2in overall lift. Is this true? Anyone used this combination?
99 Beluga Black DI SD
08 Tongan Green LR3
You can take the rear springs on a D1 and put them on the front, but it would be best to get new springs for the rear. Keep in mind that if you do then that if you add much weight to the front it will still sag because they will be worn out.
Joey
97 Disco
10 MCCSm
Custom Rover Accessories
Home of the D2 horn buttons
Thanks. Yeah, I'm not planning on loading up the front with a bumper or anything, just trying to buy time until I can afford proper springs.
08 Tongan Green LR3
In that case find a set of used rear springs. Unfortunately I tossed mine years ago.
Joey
97 Disco
10 MCCSm
Have you considered our 2" Lift Spacers as an affordable alternative:
2" Lift Spacers. Easy to install, for that DIY person. No special tools are required. Fits between axle and spring plate. Set of 2 front, 2 rear. Does not fit Discovery II's:
http://www.roversnorth.com/store/p-5...-set-of-4.aspx
Mike Koch
1993 Range Rover SWB
"Backup car? Why would I need a backup car? My car backs up just fine."
The front and rear springs and Disco, RRC and 90 are all interchangeable. The rear springs on 110 are bigger and won't fit. However...the difference is the lb/ft rating. The tallest spring doesn't always make the car sit higher. If it's not stiff enough then it will sink. The stiff short spring will make it sit higher.
I have mixed feelings about the spacers. They have potential to move. THe best way to do it is with +2" springs.
And will you change the dampers? They will bottom out and fail if you don't change them for longer versions.
That's good info. I'll change the shocks when I do it. That should control sway and make the ride a little better.Originally Posted by spacemutt
Cheers,
Brendon
08 Tongan Green LR3
So does this mean I could just buy the Genuine 90 springs for my DI?Originally Posted by spacemutt
http://www.roversnorth.com/store/p-5...eavy-duty.aspx
How much lift would that give me?? I'd like to fit 215/85's (30in) or somewhere around there. My shocks are original, so they are old and worn.
08 Tongan Green LR3
Nevermind, I found the DI HD Genuine Springs. Still would be interested if anyone runs these how they hold up/lift they provide. Thanks.Originally Posted by BDM
08 Tongan Green LR3
They don't need to be Genuine. Britpart springs are very good. They do a standard ride height heavy duty spring which will have the effect of lifting about an inch over standard. They also do +2" springs.
I have Bearmach springs on my Disco. They are fine but some of the later batches have been known to break! I think they have sorted this but you don't know if what you are getting is old stock.
If you don't want to buy longer dampers you can get mounts which will lower the damper the required amount.
Please note that is is nigh on impossible to say how much a set of Defender springs will lift a Discovery without trying it. You have to consider the weight of the vehicle and max load. Whichever is higher will have a stiffer spring. Although there is little load effect on the front when loading the back of the vehicle, the front springs have to support the engine and most of the gearbox. V8s are quite light in comparison to diesels. I don't know if you can get diesel spec springs over there.
I know your resources are limited and springs and dampers are very heavy and can't easily be shipped over.
