2.25 gas with 8:1 head (Turner motor) and Petronix ignition. I have been told that the timing chould be set at everything from 6 deg BTDC to 3 deg ATDC!! Can anyone tell me what it REALLY should be! At sea level, Florida, and confused.
shooooooooot,
the best timing light i've ever had was a fruit jar half full of water.
directions for use easy to follow as well.
#1 loosen the dizzy at the base.
#2 set jar on the wing.
#3 advance or retard the timing until water in the fruit jar is as smooth as you can get.
#4 tighten the dizzy .
#5 to easy
www.singingcamel.com
Hi Clive,Originally Posted by Clive
The reason for the variation is that Rover did not know what the fuel quality would - or would not - be. The Turner motor with the 8:1 head will have great power [for a 2.25] but it might require mid-grade gasoline so as not to "ping" under load.
First, try some regular gas and set the timing to 0 degrees TDC. If you have any inclines, put the car in a high gear and force it up a hill. If you hear a "pink" or rattle under load, then it's running too advanced. Lower it to 3 degrees BTDC and try it again.
With a new engine, the engine should run very, very smoothly. I once had my engine running very smoothly but discovered that I had it advanced much too far. So use a timing light to start. If you have no pinging and the "water jar" doesn't wiggle, you've got it right.
If it runs smoothly but still diesels a bit after turning it off, or if you get some pinging, then try mid-grade gas. I've had to use it on my 8:1 rebuild almost from the time I had the engine installed.
Enjoy the new power!
Jeff
Jeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
I was always told to retard the timing til it almost dies, then advance until it almost dies, and set it in the middle...
Is this wrong?
This is assuming that you don't have a timing light handy.
67 IIA 109" NADA Wagon (sold)
Here is another fun way without a light... put on the E-break, put it in gear, have someone push down on the gas and break at the same time, so it is under load but not moving (when I'm alone I put it against a brick wall and use the throttle cable to, well, never mind)... advance it till it starts to ping and then turn it back just a bit till it stops.
When someone tries something stupid like I'm suggesting, don't be surprised if you run yourself over. Take that as my legal disclaimer.
Rod
There are some great suggestions here - but I will reserve the Turnbull "Wall Technique" for the last resort and make sure I have someone videoing it for posterity!!
Meantime last night I set it to 3 deg ATDC - absolutely no power today, couldn't get above 40 mph even with the wind behind! But it ran smoothly and the water didn't shake. Using regular gas. Today I will set it at TDC and work up from there....and after exhausting timing options try the mid-range gas. Many thanks.
Did I mention the part about not standing between the Rover and the wall?
Best of luck.
Rod
Rod,Originally Posted by Rod Turnbull
You can't load a stick shift the way you can an automatic. If you have it in gear and it's not moving, you're slipping the clutch. This is bad.
Umm, something doesn't sound right here. Before you touch the timing, have you gapped the points? Are they new and clean? This needs to happen before you consider changing the timing.Originally Posted by Clive
Jeff
Jeff Aronson
I have installed a Petronix electronic ignition (newer type Lucas distributor) so no points to adjust.....(unless I am missing something!) however, last night I set it to 3 deg BTDC with the light and I have a bunch more power today. Still doesn't feel as powerful as it should though.
Another question - when setting the timing with a light should I diconnect the vacuum hose and set it that way, then reconnect the hose and adjust idle to 750 rpm? Many thanks for all the input, it is getting better all the time!
