I want to tow my Disco behind my RV. Can that be done with a car hauler that mounts the front two wheels?
I would not recommend it, unless you remove the rear driveshaft.
Joey
97 Disco
10 MCCSm
Custom Rover Accessories
Home of the D2 horn buttons
It is a bad idea, since you have 4X4. Look at the manual it will tell you exactly what your options are.
You can actually tow it with all four wheels on the ground.
With engine running and transmission in neutral;
Shift the transfer case into neutral (between Low range and High range).
Then put the transmission into park and shut off the engine.
Release parking brake and you're ready to go.
'04 Land Rover Discovery S
Way over 100 Off-Road Treks
I was thinking of unbolting the rear and strapping it up.
