Results 1 to 2 of 2
Thread: head gasket sealant
    Default head gasket sealant
    I bought a composite headgasket set for my D110 NAS from our hosts and Les sent me instructions. Does it need a sealant?
    Secondly I boughtthe stock Land Rover D110 springs (OEM) and the 4 springs are colour coded with a little paint slash -- which is which.
    Thanks a lot in advance.
    Abraham
    Do not use any sealant on the gaskets. Be sure to follow the torque pattern. Also, I did not use the special headbolt for the alternator bracket , I used all the bolts that came with the kit.
    Good luck...
