Check out www.tirerack.com. What you need to do is determine the diameter of your tire. then find a size that you want. i have found on that site that you can put in your tire size (i.e. 255 55r 18) or whatever and then look at the tire details and see its diameter. On my disco 1 i junked the stocks and stuffed 245 75r 16's under there. The front rubbed a bit but after a neat trim....buttah!
