It may be your brake cylinder, Take your brake drum off and see if you can move the pistons in or out be careful not to pull the piston out.
Also you may have to re-adjust the brake adjuster which is on the brake backing plate it works on a cam.
most likely a collapsed rubber brake hose, the pressure from the master forces the brake fluid through the hose past the collapsed spot but there is nothing to force it back through the other way so it will lock the brakes, remove hose and see if fluid drains.....
