I have a 1994 D-90 and it is having problems starting. I have had it in the local Land Rover dealer twice in the past 2 weeks. First, they said it was just a fuel pump relay switch. Changed it. Then, got it back, and it was dead, so I took it back in and they said the alternator was drawing power when off, I ordered the new alternator and they installed it. Now, it still doesn't want to start. It cranks over when turning the key, but doesn't start on the first try. It usually takes 4 times to turn the key before it will start. It cranks fine, but either seems like a fuel problem, or electrical short not allow it to start on the first try. Any suggestions of what it may be? It is also idling lower than it did before I took it in to Land Rover.
Thanks for any help.
