Results 1 to 6 of 6
Thread: Hylomar
    Brewer, Maine
    1,379
    Default Hylomar
    Where is hylomar supposed to be used and is it a sealer for all gaskets like oil pans and differentials? Thanks,
    Jim
    Kingsport
    613
    Hylomar is a brand, like Permatex. They make RTV, gasket sealants, locktite, etc. etc. A lot of companies have to to them for OEM products, ie, Land Rover uses their products, such as for the oil pan you mentioned.
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
    1,199
    Default Hylomar Goop....
    Use it anywhere you think you might want to take things apart without leaving gasket welded to the mating surfaces. Especially handy for valve covers, oil pans transfer case covers, diff housings, and a host of other applications. Never dries, always stays gooey.
    Use it in conjunction with the gasket, not instead. Not for high pressure.
    Brewer, Maine
    1,379
    Thank you both for your answers. I now know where hylomar is to be used.
    Jim
    Default Hylomar gooey
    Howdy Jim,
    I think the equivalent stuff available on this side of the pond is a Permatex product. I use Aviation (form-a-gasket) sealant by permatex. It comes in a small plastic can with a brush for application. Does not dry and works well.
    Brewer, Maine
    1,379
    I already had a tube which I found in my Rover when I bought it. I just wasn't sure were I should use it. Thanks for the reply!
    Jim
