Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Looking For Lockers
    Jul 2009
    Trinidad , ( Caribbean )
    14
    Question Looking For Lockers
    Does any one have, or know where i can get lockers for my 1985, 2.5 GASOLINE ,110 PICK UP, I would prefer the regular one's, not the air or electronic type.
    What do you mean regular ones? I thought they were all air of electric. They have a little solenoid inside which moves the locking mechanism into place.
    Washington DC
    513
    detroit and true tracs from keith @ rovertracks
    Quote Originally Posted by outlaw View Post
    Jul 2009
    14
    Angry There are different types of lockers people .....
    Quote Originally Posted by spacemutt View Post
    ....one my other suzuki samurai and all the poeple that have lockers......the wheels are constantly locked on the rear, so they grab a bit on corners, ...
    Jul 2009
    14
    Quote Originally Posted by daveb View Post
    ????????????????? im always off road , in the worst terrain ,hills, rivers, mud ,,and more mud ...we have an off road club..
    Ok. Just asking. Over here in the UK the only lockers fitted on the rears are either air or electric and only locked when all else fails, otherwise things go pop. I've heard of some people fitting Limited Slip Diffs which would help a bit and take out the hard work of pushing a button.
    Do you have a link to the sort of thing you're talking about? I'm keen to learn more.
    Washington DC
    513
    no problem
    www.rovertracks.com
    Guilderland,NY
    484
    I will translate his shorthand answer for you. A Detroit is a rear locker that is mechanical, always locked unless it needs to unlock by ratcheting around tight corners on pavement. It is made by Eaton in the US, http://www.eaton.com/EatonCom/Produc...cker/index.htm
    A Tru-Trac is a limited slip differential made by the same company that is ideal for the front end. Neither of these require any wiring, levers etc. and use regular old 90 weight gear oil. No special oils or friction modifiers need to be added.
    Jul 2009
    14
    Quote Originally Posted by KevinNY View Post
    Thanks Kevin and all you guys , for the help , i e mailed them for costings and weight, just waiting......for a reply..
    Unlike you all , Trinidad does not have a large group of land rover lovers, 95% of the ones here are for farm or some sort of work. mines is for recreation, ( its to good for work) ha ha ,, any how, to get spare parts is not the problem, i could get just about anything (original stuff ), so i need you guy to - as we say "Gimme ah pull out" when it comes to accessories, i really need head lamp grilles NEW OR USED, and a skid plate for the front, HEY !!! My Land Rover is my life, ......thanks again
    Outlaw
    Apr 2008
    Sennwald, Switzerland & Rockwood, PA
    153
    if you end up with a locker as described by Kevin, you might also want to consider upgrading your axle shafts - especially if they are still OEM from 1985.
    Jaime
    One Life Live It
