Ignition wire locations on coilpack
I recently did the head gaskets on my 04 disco. I was pretty meticulous except for marking the wire numbers with the locations on the coil packs.
I believe I have the cylinders identified correctly:
Drivers side from front to back: 1,3,5,7
Passenger side from front to back: 2,4,6,8
Is this right? Now there are numbers on the wires 1-8. Am I right in assuming these must correspond with the cylinders?
On the back of the coil packs, there is a right and left side. Each coil pack is labeled 1,2,3,4. I need to figure out which cylinder goes with each coil pack location.
If anyone knows this info and is kind enough to help me out, it would be greatly appreciated! Thanks
