Results 1 to 7 of 7
Thread: Anyone Have an Extra Crank I Can Buy From Them?
    Default Anyone Have an Extra Crank I Can Buy From Them?
    ....for the gray Rover? I'd like to try to turn the engine over this weekend but have no crank
    North MS
    980
    Crank implies crankshaft. I think you mean the crank handle, or starting handle.
    Oh, and if it won't turn over with the starter, there is no way it is going to turn over with the starting handle.
    67 IIA 109" NADA Wagon (sold)
    Quote Originally Posted by jp-
    yes, that's exactly what I mean...sorry.
    I thought odds were better trying to use a starting crank after letting the Marvel sit?
    North MS
    980
    You can use the starter. I'd make sure that the oil in the crankcase is fresh, that the plugs are out, and the coil is disconnected.
    starter won't do it....I tried it two weeks ago. well......that was before letting the marvel sit. everyone else said to use the crank, get it unstuck, then crank it a few times to get some oil pressure to the valves?
    Vinalhaven, ME
    569
    Default Extra Crank
    They're not that expensive. I bought a new one for my second II-A from Rovers North.
    Once, when my Rover would not start on the starter, I yanked on the crank to start it. Instead, the crank snapped in my hand. They don't really give that much leverage. You might want to try a breaker bar and socket on the starter dog or the crank pulley, instead.
    Marvel Mystery Oil or even diesel fuel down the cylinders should help to free the pistons. If you can get it to turn, put in fresh oil before you actually try and get it to run on the ignition.
    Good luck,
    Jeff
    Jeff Aronson
    Vinalhaven, ME 04863
    '66 Series II-A SW 88"
    '66 Series II-A HT 88"
    '80 Triumph TR-7 Spider
    '80 Triumph Spitfire
    '66 Corvair Monza Coupe
    N. York
    1,635
    Order one from RN today and you'd have it by the weekend. You may need wrench or socket to try to move a really stuck engine.
    Land Rover UK Forums
