Every time I'd ready to give up you guys come back with more advice that I'm dieing to try... just leave me, save yourselves!
Joking aside, I'm coming around to the conclusion that it may not be our weekend ride again anytime soon and I can live with that I guess - but we do have street cleaning coming up so if I can't move it soon, the city may do it for me. To that end, I'm going to take the common theme here and pick a problem - getting it running. Tell me if I'm wrong, but if I had to move it 400 yards to avoid a costly tow, I could at least use a combo of engine breaking and the hand break to bring it to a stop.
This is great info - really builds on what I have learned from talking to the guys at RN and the other posts here. Thanks Tim, et al!
Part of the problem is me understanding what the various parts are - I found some diagrams and now think I know what the lobe is (for instance) and the other part is learning how the system works. Its starting to sink in.
I got a set of feeler gauges so in theory I should be good there. I've also go some super fine wood working sand paper - any difference between that and the automotive stuff?
I've tried moving the belts and they just slip, but hopefully the 1-11/16 socket on its way will help me turn the engine. I'm still not exactly clear what I'm looking for but suspect it will become apparent as I get deeper into it - and of course I'll be asking a lot of questions here.
Wow - didn't even see that nick in the insulation - will get right on it, good eye! Again, goes back to learning more about how the system works...I guess that's the benefit of having to do this myself
Thanks again folks, I'll continue to keep everyone posted.
I can't really help out with your mechanical problems Nick and these other guys have got you covered, but when it's street sweeping time on my street and my truck is down, I put a big note in my road side window glass that says "broke down sorry, parts on order" and they haven't ticketed me or towed me. Of course, they are used to at least one of my Rovers being broke down at any given time. However, your area may be much tougher so use with caution.
1966 IIa - ex-MOD, ex-FFR, ex-24v
1997 Discovery SE7 - I'm empty inside without her
Nick, The lugnuts on my Rover(s) take a 1 1/16" socket. That's a good socket to have when you own a Land Rover.
There's a thread on this forum about OEM versus aftermarket parts, and I think the same sentiments should apply to tools. Sometimes saving a few bucks on a cheap tool is false economy. So where you ordered the socket from Amazon, that's fine except you have to wait for it and it could be poor quality. Sometimes inexpensive tools work great, sometimes they're junk.
My toolbox has some cheap tools in it, but most are the more expensive brand name tools. For sockets and wrenches... my opinion is that you should stop by a Sears store and purchase Craftsman (certainly not the only option, but most people can find a Sears store near them). That way you've got a good tool, and you've got it now.
Yeah - I'd agree with that. I have a full craftsman wrench and socket set that I love - just nothing that big. I've had it since I was like 7 so its likely that I've lost the 1-1/16th if I ever had it.
After remodeling our house ourselves (where is the internet forum for that!?!?) we got good at determining good tools from rubbish.
My amazon order was a get-er-done thing, but there is a rumor that Sears is sponsoring the classic car show in town this weekend and will have tools for sale at a large tent. This could get dangerous !
What classic car show???
I think the proper stuff is called emery paper but lately I've just been using plumbers sand paper. If you're doing a remodel, then I bet you have some of that laying around.
Regular fine sand paper should also work but sometimes it leaves some of the sand behind. Just make sure there aren't any grains stuck in between the points when you are done and you'll do fine.
You also have new points on the way right? Once you swap them in, you should still clean these ones up for practice and then keep them on the truck in case the new ones fail down the road. It's a good to have on board sort of thing.
Well, I got the new points, distributor cap and coil (hey, why not?) installed.
I was able turn the engine just enough with the pulleys and gaped the points with a feeler gauge. Not going to lie, felt pretty proud of myself.
but it still won't start
I checked the fuel lines - they are clear and pressurized (IE fuel spurts out when I disconnect them). I thought there might be a blockage in the carb, but when I move the pump mechanism I can see it spraying fuel into the bowl (understanding that my terms may be incorrect).
I had the key on and examined the points, I manually opened them and saw a spark. Glad I had rubber gloves on... so I'm guessing that means there's at least current moving through them.
Any other ideas? now that I'm looking at the old points (and can tell what the "points" actually are) they look almost brand new. Guessing that was never the problem.
____
Since I had the day blocked off to working on the rover, I am going to jump back on the breaks. Just to confirm that I'm not crazy, the lugs to come off counter clockwise, right? I've got a longer 10' section of pipe and going to give them hell with a breaker bar and 1-1/16" socket before giving up and finding someone with an impact wrench.
Good job! I thought the installed points looked new. Keep them for later.
And the rotor button installed too, right? No rotor, no go.I got the new points, distributor cap and coil (hey, why not?) installed.
Now you need to statically or stationary set the timing (whichever term you prefer). Remember you threw it off in tinkering. Don't use the timing gun.
Once you get the timing set you are going to have to monkey around with the idle adjustment a bit on the carb to get it to idle long enough to warm up to operating temp. Once at operating temp you can set the idle and forget about it.
Have you replaced that torn apart rubber boot on the vacuum advance of the dizzy that is a BIG vacuum leak that needs to be rectified. If you don't have a replacement use duct tape till you do. That should be a fitting available at the local auto parts store in the vacuum fittings aisle/area.
A spark from a spark plug or from the coil right? Not a spark from in between the contacts of the points?had the key on and examined the points, I manually opened them and saw a spark
Cheers
Walker
1968 Series IIA-"Ronnie"
88" SW, 2.25L Petrol, LHD
