The great thing with the 2286cc diesels is that you dont really need to do anything with them. After thay have had their dizzypump set up properly so the run well, there is nothing to do except normal servicing, which is oil, new oil filter, diesel filter and clean out the air cleaner too. No need to change glow plugs untill they stop working, which should be years. No points to adjust or spark plugs to clean.
The only potentially pricy thing is reconditioned injectors, but they dont need to be changed very often, they will go for thousands of miles before they need attention.
So as you see, less hastle to service than a petrol lump. And you never need to worry about starting on a damp morning again
