FWH for 101
Collapse
X
  • Time
  • Show
Clear All
new posts
  • leafsprung
    Overdrive
    • Nov 2006
    • 1008
    FWH for 101
    Im looking at building some FWH for my 101 front axle. Any interest from other owners?
  • greenmeanie
    Overdrive
    • Oct 2006
    • 1358
    #2
    I can only think that would be interesting to a lot of owners to allow them to get around the infamous front prop shaft rumble on long runs. Of course, you'd want to sell an LED conversion with it for the diff lock light as that melts the warning housing in the dash if left on too long.
    If you want some spirited response and to generate the interest to make economy of scale more viable I'd suggest posting it up on the forward control club forum. I think one of the club comittee posts up very occasionally over on Pirate.
    101 club forum
    Mind you, we Brits are a tight lot when it comes to our Rovers so expect a lot of people to whine when cost is mentioned. It does strike me as a far simpler and hopefully cheaper solution than rolling diffs, fancy prop shafts and 2wd linkage conversions to an LT95. I'd suggest offering them a production run of those disc brake mounts you did too.
    I'd be interested to see them but right now I'm mortgaging my left kidney for my 109 build.
    • robert wood
      Low Range
      • May 2009
      • 37
      #3
      I built a set for my friend Chris Palmer about five years ago. We used an old set of American made ones with the two flip over levers and made new central cogs. Worked a treat. Ray
      • IIA Lightweight
        Low Range
        • Oct 2006
        • 56
        #4
        got my intrest up
        69 Lightweight
        With Rover V8
        Does a body good
        • leafsprung
          Overdrive
          • Nov 2006
          • 1008
          #5
          Would not want to base them on the dualmatic (lever type) they are very prone to failure.
          • airbornrover
            Low Range
            • May 2012
            • 17
            #6
            There is a pair for sale on ebay uk.
            • greenmeanie
              Overdrive
              • Oct 2006
              • 1358
              #7
              http://www.ebay.co.uk/itm/1209747525...84.m1438.l2649
              These are 24 spline for a series 3. They do not fit a 101 which is 22 spline.
              Working...
