Originally Posted by
GeoffWillis
...The manual talks about aligning marks on the flywheel but I see no access point to the flywheel to do such an alignment...
Geoff
Geoff, there is a rectangular cover on the flywheel housing on the right side of the engine, near the top. Look down below the fuel filter mounted on the bulkhead. Remove the two screws securing the cover, and inside you will see the flywheel. You will need someone to rotate the engine while you look for the timing marks to come around. Just above that cover is a plug. This is where you are supposed to insert the timing pin that "locks" the engine into position for proper timing.
There is a tool that you can use to hold the injector sprocket in place while you change the pump but I think they are pretty pricey.
Brett
Series 3 88 Diesel Soft Top
Ex-Mod 110 Tdi
