Results 1 to 5 of 5
Thread: Engine Timing
    Nov 2007
    Central Coast California
    19
    Default Engine Timing
    Truck is idling a little high...clean the idle air control valve (that helped some....) They have told me the timing is out a little which could cause it to idle higher. Can someone tell me how to adjust the timing?
    Trying to get the car smogged and they will not pass it because the idle is not with specs.
    Thanks for the help
    Oct 2006
    Ridgefield CT
    309
    There is no way to time a P38 Range Rover. There is no distributor!
    Kevin
    04 XJ8
    92 RRC
    02 Benz E320
    95 RRC (sold 5/10)
    72 Series 3 (sold 4/10)
    70 Series 2A (sold 6/10)
    Morgan +8 (sold 8/09)
    72 Triumph Stag (sold 1/08
    Nov 2007
    19
    Default Timing
    Ok..thank you.
    Can you tell me what is done in the place of the distributor?
    Oct 2006
    Ridgefield CT
    309
    Coil packs and an ECU that controles Ign
    Kevin
    04 XJ8
    92 RRC
    02 Benz E320
    95 RRC (sold 5/10)
    Nov 2007
    19
    Default Thanks Kevin
    Thanks for the information
