Why won't an overdrive work with a hi ratio Xfer case??? I remember reading this somewhere, but cant remember why.
Visit The Wandering Hippo (my 109 S2A Ambulance).
My guess is that they are getting the "high ratio" out of the input gear which (if memory serves) is where your fairey or roverdrive pops into the works. That would mean that the connecting overdrive gear wouldn't mate up any more.
Just a guess though...
Regardless you would get unuseably high gears.
But... But... It might go 100mph!Originally Posted by KevinNY
It would be Land Rover history!
67 IIA 109" NADA Wagon (sold)
The high ratio kit comes with a new set of gears with different numbers of teeth than stock. An overdive gear will not match teeth with high ratio gears.Originally Posted by KingSlug
My Land Rover has a high ratio xfer case, stock R&P and 33.3" dia tyres. I just ran the numbers, and my engine would turn 4,126 RPM @ 100 MPH.
The same LR with stock transfer case would be going 75.7 MPH at the same RPM. With stock 109 tyre dia & stock xfercase the LR would be going 72.7 MPH @ 4,126 RPM. 100 MPH would be 5,675 RPM
If you run the numers, you get almost identical ratio with an overdrive and 3.54 R&P as you would with a high ratio transfer case and overdive.
So get some RR Classic diffs, a Rover drive and knock yourself out.
Teriann Wakeman_________
Flagstaff, AZ.
My Land Rover web site
I don't think that will work- Jared wants to crawl too.Originally Posted by TeriAnn
Jared you still want to use the MB diesel don't you? You'll need higher gears but not by a lot. 4.11's would be good.
I am looking at a Cummins 4BTA/NP435/Series Xfercase/Toy Diffs. The 4BTA has a cruising RPM of 1800, so having a 4th/OD would be advantageous. With the NP435, an "B" low gear and the grunt of the 4BTA I should be able to creep along, but I wont be rock crawling.
Sounds like a good choice with the Cummins. I'm looking at that possibility as well for my 109,w/ Toyota Axles and possibly SM420/465, I'm not sure which transfer case I want to use yet. I have a NP200 on the way and may use it to make a passenger offset NP205. Actually I'd like to use a 203 reduction unit with it but that would be overkill especially with a diesel. 116:1 Decisions decisions...
What size tires are you planning to use?
I suspect there is an unspoken, unwritten law of physics, that the only time a series rover will go 100 mph or more, is going straight down hill, (like over the edge at Dead Horse Point), but your next of kin would be stuck with the EIS, and cost of cleaning the smudge from the slickrock.
Or possibly following ignition of your Genuine Parts brand JATO pod.
I rebuilt my 2.5 L 4 cyl engine in 1996, with pistons .030 over, planed
the head for increased compression ratio, added the 2 bbl webber carb, electronic ignition, Detroit soft locker, heavier axles, all of which gave the truck the ability to keep up at 65-75 mph, without straining the engine. I have had a Fairey overdrive since 1981, which added top speed, decreased engine strain. I have to use 88-91 octane, to prevent pre- ignition.
The 4 cyl Rover engine works very well for climbing, driving, etc., except for being a little slow. The original equip. trans, trans. case, function well with regular care, maintenance. Original equipment is very easily rebuilt, and easily repaired, with all parts still available for series 2 vehicles.
Considering the cost, and changes required to install a very powerful engine like a Cummins, someone might save some money purchasing a new truck, like a diesel Discovery, or Defender 90 or 110.
Saving money by buying a NEW diesel land rover? What kind of conversion costs 35-50Ksomeone might save some money purchasing a new truck, like a diesel Discovery, or Defender 90 or 110
There are several series rigs out there that will pull 100mph with relative ease. Luckily Ive only been clocked going 90 . . .
A high ratio overdrive could be made from a normal fairey and a ashcroft input gear. The fairey input gear would have to be cut off, the ashcroft gear bored out and then welded to the fairey.
