I am about to replace my air suspension with RTE springs, 2 inch lift and Old Man EMU shocks. However I am concerned about the ACE system. What are the considerations?
Thanks Rob
Thanks Rob
I have a 2001 d2 went to coils and further. Nothing to woory about just remove everything to do with the system. Little brackets with all the pipes and the pump the fan belt and the pulley.Done . My local land rover dealer wasn't able to turn my dash warning light off though. Then order a shorter fan belt from rovers north #RNH145- $38.00. Of course you need the coils. Don't have that part # I went to all 4 OME with shocks#OMEdsk2k2.
The other thing is you'll have to call them (R.N.) because I took everthing off. I'm not sure about just the rear air to spring change.
This might be too much info but here's what I put on. Works better than my old '95 D1!
4-bolt to body duo-tapite RND790-$13.00
1-shorter no/ace fan belt RNH145-$37.95
2-upper rear isolators RND736-$26.00
2-lower rear isolators RND821-$26.00
1-OME stearing damper-omesd02-$77.00
4-OMEHD spring/shocks-omedsk2k2-$660.00
1-rear anti-roll bar no ace-RND813-$150.00
1-front anti roll bar no ace RND796-$110.00
Total w/o shipping $1100.00
Worth it? Yes!
Don't follow me you won't make it !
Good luck RVOEN never use R
Roven,
Do you have any pix of your current set up?
Would be kinda nice to see a before and after..
Les Parker
Rovers North Inc.
No sorry I took no photos of this. My wife actaully brought that up while I was cleaning up all the ace fluid on the garage floor.
