Page 219 of 229 FirstFirst ... 119169209217218219220221 ... LastLast
Results 2,181 to 2,190 of 2287
Thread: What did you do to your Rover today?
  1. #2181
    Apr 2012
    Bergen County NJ
    265
    Steve, did you use a Poppy Red color code, or just tell 'em "bright red" ? Limestone for the sunsheet or white?
    Looks great
    well faded, patchy, lumpy, poppy red here
    ~Steve
    ---- 1969 Bugeye ----
    ---- 1962 Dormobile ----
  2. #2182
    Jul 2012
    Little Rock, Arkansaw
    83
    Quote Originally Posted by Revtor View Post
    Looks great
    ~Steve
    Poppy Red color code. I repainted it because the paint on the doors and roof was peeling off in sheets. My primary concern was preservation of a remarkably solid 109. Had it retained a nice, relatively uniform patina I'd have likely kept it as was. I didn't paint the interior of the tub partially because of extra cost and partially because this is going to be a user so it'll get scraped up and mainly because I like the patina. I've buffed it up a bit and it looks fine, used but fine.
    Steve
    1962 Series IIA 109 Station Wagon
    1994 Defender 90
  3. #2183
    Jul 2012
    83
    Looks great
    ~Steve
    Oh, and limestone for the sheet and wheels.
    Steve
    1994 Defender 90
  4. #2184
    Nov 2012
    Helotes, Texas, USA
    72
    Fitted new seats in my 88. Click image for larger version.
    '73 Series III 88 2.25l Petrol, '06 LR3, '08 Range Rover Sport Supercharged
    Helotes, Texas
  5. #2185
    Feb 2014
    Dallas, TX
    82
    Manny, those look sharp!
  6. #2186
    Feb 2014
    San Antonio
    21
    Looks great! I sent you a message.
  7. #2187
    Nov 2012
    Helotes, Texas, USA
    72
    Jester065 I replied to your message
    Helotes, Texas
  8. #2188
    Nov 2011
    Wellesley, MA, Ludlow, VT
    72
    Replaced Right Rear Brake Pads. Previous ones were soaked with oil after hub seals leaked for many moons in previous owners barn. I had originally tried full can of brake cleaner to degrease, but after driving on them a bit, I checked them out and they looked like they were "bleeding" oil. Of course, I at first I mixed up the leading and trailing brake shoe position...
    I saw some posts on an Aussie LR Forum that said to soak the pads in gasoline and "burn out" the oil since the pads are asbestos and will just burn off the oil. I figure for the price of a new set of pads from our hosts, I would save the burned eyebrows and just order new. I did see some references out there to the drums potentially being saturated and should be replaced, but I will try as is. The drums seem fine.
    1971 Series IIa 109 Ex-MoD
    1994 Landcruiser FJZ80, ARB Front Bumper, Old Man EMU suspension
  9. #2189
    Quote Originally Posted by cedryck View Post
    If you are concerned about wiring, the rewire on a truck like this is really idiot proof. Make friends with the wiring diagram, label everything as you dis-assemble, and order a new harness. Solves alot of the stupid problems old rovers have with old wire. Cheers.
    I may be too big an idiot for that even. I have a new wiring harness sitting in my parts pile. Haven't summoned the nerve to tear out the old one. Maybe someday.
    Tom
    1969 Series IIA 88"
    I like it because I understand how it works (mostly).
  10. #2190
    I tackled the rear end this week - mechanics have been telling me for years that my rear diff sounded bad, and the way it chewed up U-joints in the prop shaft seemed to suggest too much slop. The rear axle casing was also disintegrating from rust and oozing oil from various pinholes. I sourced a good used casing from Pangolin and a good used diff from our hosts (an excellent one, in fact- the gear cluster looked virtually unused, although the outside had old paint and rust on it). I started tearing out the old stuff last Monday.
    Always a mess getting old parts out. I also got new u-bolts for the spring since I suspected my old ones would get damaged during removal. I have parabolics and it turns out the standard u-bolts are too long, since they are designed for that massive 11-leaf Rover spring pack. I ended up just going to a local machine shop and having them make me new bolts in about 10 minutes.
    I POR-15'd the axle casing and surface of the new diff. It all went together more easily than it came apart but I was sore from turning wrenches on stuck nuts and so forth. Buttoned it all up yesterday and took it for a tentative test drive and thank goodness it all seems to work. That shiny black axle and diff look great under there. It was a job to hoist the new diff in place- that lump must weigh 50 pounds- but with my floor creeper and some wood blocks I managed to get it lined up and on by myself. The entire repair only cost maybe $700.
    By the way, I now have my old diff, which doesn't look terrible and someone might be able to rebuild/use. PM me if interested.
    Cheers,
    Tom
    Tom
    1969 Series IIA 88"
