Results 1 to 7 of 7
Thread: Going through Oil
    Jan 2010
    7
    Default Going through Oil
    I just replaced all the seals on my 97 RR 4.6 engine. Since then I have been burning more then I should. Oil light when on with only going a 1,000 miles. Any thoughts? Thank You.
    Feb 2009
    Cincinnati
    130
    Are you burning it or leaking it?
    If burning you should see your Cats clog up soon, if leaking it... I would say time to find the leak. Just because all the seals have been replaced doesn't mean one isn't leaking.
    Joey
    97 Disco
    10 MCCSm
    Custom Rover Accessories
    Home of the D2 horn buttons
    Jan 2010
    7
    No it's not leaking. I took it back for inspection, they didn't find anything.
    Feb 2009
    Cincinnati
    130
    If your burning... valve seals or piston ring issues.
    Joey
    97 Disco
    10 MCCSm
    Jan 2010
    Austin, Texas USA
    2
    Default check your breather valve...
    check your breather valve, also change your air filter to a high quality air filter. My son had a clogged up breather valve on his SUV, was burning oil rapidly. After fixing the problem, burning stopped, power restored.
    Jan 2010
    7
    Thank You. I don't see any gray smoke coming out of the tail pipe. I hope it's just Breather valve.
    What is a breather valve?
