On my 88" there was not enough adjustment in the door hinges to allow the door to meet the tub at the right angle. So I removed the hinges and drilled out the 5/16" mounting holes several sizes larger. I rebolted everything with small washers to cover up the slightly larger holes. This gave me all the adjustment I needed to line everything up. Once lined up, just have someone tighten the door bolts and bulkhead bolts, while you hold it all in place.
67 IIA 109" NADA Wagon (sold)
