Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Injection Pump Returns!
  1. #21
    Apr 2008
    The Granite State (NH)
    3,435
    Default Biodiesel
    Geoff, Just curious...had you run biodiesel through your pump before it began leaking? I've been doing some research on biodiesel's benefits over the ultra-low sulphur diesel when it comes to lubricating older pumps like ours. It seems that any diesel engine can run B20 biodiesel blend (20% ratio of bio to non-bio), but higher concentrations will effect natural and butyl rubber seals and could cause leakage in the fuel system components unless they were built (or rebuilt) with biodiesel in mind.
    Anyhow...Just wondering if higher blends of biodiesel killed your pump.
    Info on this from the National Boidiesel Board here.
  2. #22
    Oct 2008
    San Antonio, TX
    101
    Default No bio-diesel
    No, I never ran bio diesel, but did run gas... Long story and my son feels bad enough.
    Geoff
