Originally Posted by
Woodslug
I checked the gap on my 88 and it is about 1/4" on one side and close to 7/16" on the other. The gap is there so the bottom of the door won't hit the skirts that run under the door.
Ted
This is correct.
Ideally, the gap is the same all around the door. On a rover, this is all but impossible...
I find that if you mount the tub first, then the bulkhead and doors, you can get it to line up quite well. Mount the doors (loose) and use a come-along to move the bulkhead into proper position. (no latches on doors) adjust until the body line lines up and the front and rear gaps are the same. The rocker trim sits against the bottom of the rear body tub, and under the door. This gap should be the same as the front and rear gaps of the door. Once all this is aligned, start tightening bolts on the bulkhead and doors. THEN install the latches and be sure the door skin is flush with the tub side. THEN install the door seals last.
If you do it in this order, everything will line up and work correctly. You may even reduce the amount of water that pours in when it rains.
FREE TIP: use the defender seals rather than the series door seals... They work SLIGHTLY better.
1995 110 Regular
