Results 1 to 3 of 3
Thread: Diff housing bolt pattern
    Mar 2007
    Killingworth CT
    351
    Default Diff housing bolt pattern
    I bent my front 24 spline housing and I need to replace it. I have a number of 10 spline housings sitting around, will the 24 spline diff fit without redrilling the face where the diff bolts on? I am away from home otherwise I would just go look. Thanks.
    May 2006
    2,020
    As long as the 10 spline housings have the hole for the ABS sensor, you should be OK, the other feature is the brackets for the anti-roll bar.
    Mar 2007
    Killingworth CT
    351
    Thanks Les,
    I have 24 spline knuckles, I just didn't have an extra housing. I also ditched the sway bar long ago so I should be fine. My dads 109 front end has been tweaked for too long, he will be glad i finally have the time to fix it.
    -Forrest
