Results 1 to 4 of 4
Thread: outsite temp
    Feb 2007
    19
    Default outsite temp
    Hello Guys
    Would any one know where the sensor for outside temp would be?
    I cant find anything in the work shop manual.
    This would be for a 1998 4.0 SE the reading is a bit more than it should be. Thanks
    Feb 2007
    19
    Found it and replaced it!
    May 2006
    2,011
    Hello there,
    Would you please share where you found the sensor?
    Could assist others in their quest.....
    Les Parker
    Rovers North Inc.
    Feb 2007
    19
    Quote Originally Posted by Les Parker View Post
    Hello there,
    Hello Les
    the sensor is located in front of the ac condencer drivers side
    if you look through the louvers on the air dam you will see the tip of it.
    To remove it take off the plastic grill,use 12 inch angle needle nose pliers
    half turn to remove,lift out.
