Results 1 to 4 of 4
Thread: 95 Range Rover LWB ticking noise - engine
    Default 95 Range Rover LWB ticking noise - engine
    I bought a 95 Range Rover LWB and noticed a ticking noise coming from the engine. The local dealership suggested that the problem is common to this year model stating the oil pump didn't function well. I changed the engine oil with 20W-50 and used oil treatment as they suggested. My Rover only has 68K miles and would hate to think it's due an overhaul.
    Any suggetions?
    Dav
    city of maples
    398
    ticking noise you say, its not normal for them to tick.
    a few things it could be:
    #1 weak oil pump
    #2 clogged pick up tube in the oil pan
    #3 exhaust gasket leaking
    this is the most common problems..good luck
    May 2006
    Westford, Vermontistan
    82
    In additon to what singingcamel suggested:
    If the engine oil wasn't changed regularly, it could be the lifters.
    Mike Koch
    Mike Koch
    1993 Range Rover SWB
    136
    are you sure its not the clock in the dash?
    jk
