Land Rover Defender Crew Cab with a 200tdi turbo diesel Engine.
This vehicle will take you where you want to go, and never fails to turn heads.
· 154,000 miles I have personally put almost 2k on this truck this spring. Including a 500 mile camping and four wheeling trip with the family. As she sits we averaged just over 23mpg, running 65mp.h
· Fitted with a Defender 200 TDi engine and LT-77 gearbox.
· The bulkhead is solid. Frame is solid as seen in pics. Door bottoms are solid.
· Brand New Bonatti Grey Paint job in excellent condition.
· Has the rear Salisbury rear end with the popular disc brake conversion done.
· Newer exhaust
· Front A Bar
· Snorkel
· Rock Sliders with wing protectors.
· Rear Equipe Diff Guard, front diff guard
· Heavy duty steering track rods and tie rods.
· Alloy Checker Plate Wing Tops & Rear Corners
· Rear sliding window
· Two Inch spring lift, with dislocation cones
· Truck has all new red poly bushings.
· 33x12.50x15 Pro comp tires fitted to Steel wheels.
· For more pics go to http://s237.photobucket.com/albums/ff251/draaronr/85CrewCab110/
· Asking 24,950
can be converted to LHD for $4k more.
