Wood Dash panels for RRC - HELP
I need urgently, 3 of the metal brackets that go on the back of the wood replacement panel in a 1989 RRC Dash. These are the ones (there are four of them) above each vent held on by 3 small screws. they SHOULD have little legs either side that the air vents snap into. They are not available from Land Rover so does anyone have any on an old scrap wood dash where the veneer has lifted off? I have a pile without the extra legs ... but these are no go as the vents cannot snap in.
Can you RSVP ASAP please as if you cannot help I will have to resort to having to fabricate them.
Paul
Well a company called LRR in UK were able to supply these - second hand, but that is fine. So I am OK now.
