transmission gaskets
any reason why one shouldn't switch to permatex gasket sealant (or similar), when mating transmission components (e.g., transfer box to main casing).
the manual calls for grease, but i'm thinking a real gasket sealer in addition to the paper gaskets may eliminate leaks.
if there is no real difference, i'll save my money and keep using bearing grease.
1970 88 IIA
