Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 95 Discovery/tuning CB radio
  1. #11
    Jan 2007
    NH
    8
    Default CB Radio
    I have been doing some research and decided to go with a cobra. The model is the 29 wx NWST. I am shopping around for my best price. Radio Shack has it for $159.00. What about the antenna? Should I get the dual or single? What type of mount for it? Thanks for the info. Jeff
  2. #12
    Mar 2007
    New Hampshire
    62
    You should only need one antenna (I assume dual vrs. single implies)
    -I drilled the antenna bracket onto the spare tire
    carrier - the antenna just screws into it and two
    opposing fittings assure a tight fit.
    I used a Barjam 4 ft. antenna - wired the cable through
    a hole I drilled in the rear cargo door - weather sealed grommet used.
    Then it is routed through the cable casing used also for the
    rear window-wiper motor cable (can be found at the door hinge.)
    the CB cable comes out through another hole drilled
    in the panel (roughly 4" x 7") behind the passenger side jump seat.
    Those were the difficult parts. Then just routed it under the rubber mats/drivers seat to
    the CB. CB is attached to the center console (sits vertical), next to my right leg
    Of course this is a "more professional" method. (took awhile)
    There are other, easier (less professional) and/or more professional alternatives out there.
    Hope this post helps - cheers!
