Originally Posted by
jac04
I was given the 3rd degree by the CT DMV when I registered my fully restored '63 88". They at first had a problem with the VIN tag being held on by screws instead of rivets. I had to show them the picture in the owner's manual which showed the screws on the VIN tag. Next was the front wheel bearing end play. I have 7.50-16 tires, so the bearing end play looks excessive out at the OD of the tire. I had to show them the workshop manual and the required bearing end play. Then came the brake test. They claimed the balance was off, but the vehicle didn't even have a hint of pull under hard braking. Luckily I brought a wrench to adjust the 'snails' on the brakes. I also got a hard time because there are no windshield washers. I had to explain that they never existed on this vehicle.
Sorry to ramble on, but if you are newly registering a vehicle you may want to be prepared for some of these issues.
