Soft top frame mod needed?
  • WineCountryRover
    • Feb 2024
    • 13
    I noticed the frame for my soft top has little flaps of metal above the slotted rail where the vertical portion meets the sides of the soft top. Am I missing something to slide the fabric in or do I need to carefully cut and fold these flaps in?
    Just got on the forum. Trying to figure out how to have the picture post without clicking a link.
    Thanks all! Excited to be here!
  • jp-
    • 981
    Here's a full install video. https://www.youtube.com/watch?v=VPouAISNGoA
    The canvas has to tuck into the header rail and side rails.
    Header rail install is around 8:50 in the video. Side rails at 9:07.
    67 IIA 109" NADA Wagon (sold)
    • WineCountryRover
      • Feb 2024
      • 13
      Looks like the video has a set of rails that don't have the fold of metal at the top covering the vertical rail.
      • jp-
        • 981
        No it's there I believe. If you stop the video at the 6:00min mark and look at the bracket welded to the hoop, the top of the bracket is recessed (into the body) and the bottom sticks out (away from the body). In your photo it looks like the bracket welded to the hoop bar has been welded on the wrong way round (left side on right and vice versa). The top of the bracket is supposed to be in more so that metal lip drops into the top back edge of the side channel. I can probably get a better photo for you when I get home.
        • jp-
          • 981
          I had it reversed. It looks like the bracket is correct. Anyway, here's pictures of how it should look and fit.
          • WineCountryRover
            • Feb 2024
            • 13
            Mine are on the right way. Guess this was some sort of manufacturing error from the factory. Planning on a bikini top for spring and summer now anyway...
            Thanks for the input.
            • jp-
              • 981
              Can you post up a picture of the inside of your bracket mount? It almost looks like the top of the side channel may be bolted to the back of the hoop bracket and it has to be mounted to the front.
