INSIDE REARVIEW MIRROR CLIP...
  • Donagh
    • Jan 2007
    • 30
    When I purchased my pre-owned 2000 RR HSK, the rearview (inside) mirror was not attached because the previous owner had broken the mounting clip on the mirror. I checked with Land Rover, and they don't sell replacement clips. I've called salvage yards, and looked on line, I even tried a 'cam lock' part, but I can't find a replacement clip for the mirror.
    I don't want to replace a perfectly good mirror (to the tune of $300), just because I can't find a simple steel clip that holds it to the windshield. Has anyone encountered this problem and remedied it, or does anyone have an idea that I haven't thought of? (or maybe even have a clip in their spare parts box they wouldn't mind selling to me)?
    Thanks in Advance.
    I remain looking forward,
    Donagh
    'Maybe the 'Hokey-Pokey' really is what it's all about.'
  • Mungrol
    • 20
    Are you serious????
    Mate,
    Ask the dealer what they would do in the event of replacing a windscreen? You saying that they are going to have a brand new windscreen that comes with the clip mounted? We are talking about the section attached to the windscreen right? Would a new mirror even come with one? Have you tried rovercanibal?
    I agree... there has to be a better way than throwing away $$.
    Keep us informed for sure.
    Cheers,
    Curly
    • rangeroverranger
      • 7
      Why not
      You know, when my mirror went south, I replaced it with a new $13 generic from OReilly. A glass shop glued the new clip on the windshield for $5, and I have a functional tilting mirror that works better than the electronic $300 dimming mirror ever did, and it won't drip goo onto my dash when it fails and leaks. I left the original clip glued to the windshield.
      • Donagh
        • Jan 2007
        • 30
        Nope, I'm dead serious... The clip is attached to the back of the mirror stem with s a single screw. (The part attached to the windscreen is called a nipple, or cam)
        I actually want to use the original mirror and will risk the 'goo' running out of it, if it fails. (Typically, I don't speculate on the possibility of bad things happening and consequently compromise my lifestyle accordingly)
        But I hadn't heard of rovercanibal, and so thanks for the tip, it will be my next stop.
        I'll let you know how I fare, and if anyone else has a source for hard to find RR parts, I'd be be very grateful to hear about it.
        Best,
        Donagh/Connecticut
