Stuck in select neutral 96 4.0
  • oneohsix
    • Apr 2007
    • 12
    Truck was shifting fine then I showed my son how low range worked and now I cannot get it back into high! It is stuck in low range with select neutral light flashing. Tried everything to get it out but will not select high! Can you overide the motor and manually shift it back to high! I promise I will never try low again.
    Thanks,
    Rob
  • Robison Service
    • 12
    Go under the truck and locate the transfer case range motor. It's on the right side rear of the transfer case. Rap it with a hammer and try and switch ranges. If it still won't switch, remove it and manually screw the motor arm in or out to get back to hi or lo range, and fix it before you get stuck again.
    You will need a specialist with the Land Rover test gear to talk to this system.
