Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Trickle of fuel to carb - is this normal?
  1. #11
    Aug 2020
    chilliwack BC Canada
    87
    The problem with changing things are the fuel line fittings. They are of a thread type that I can not find a match for. I would prefer steel to the plastic lines.
  2. #12
    Sep 2010
    killingworth CT
    836
    Quote Originally Posted by wrongway View Post
    You would have to make a junction piece, from threaded to flexible fuel line with clamps, it would work but if I do this changeover with the Ford Bronco valve, I would need to have flexible fuel lines, and that means clamps, not crazy about that, but will further investigate and hopefully post some pics,
  3. #13
    Jul 2020
    UK
    301
    I fitted a twin pump SU , two inlets & one outlet , to use with twin tanks .It wont pump between tanks due to its none return valves. Just needed a changeover switch for the electrical side. It was used on the Rover P4 range of cars for operation of the fuel reserve, one pick up pipe is lower in the tank than the other
