Welding Stainless Steel
Collapse
X
  • Time
  • Show
Clear All
new posts
  • chrisste
    Low Range
    • Aug 2008
    • 8
    Hi all, I'm about to weld a Rovers North stainless steel replacement center bulkhead assembly into place on my SIIA. Anyone have any experience or recommendations for wire (309)? Can I use 75/25 gas mix to join the stainless to the mild steel bulkhead? Here are photos. Thanks.
    Chris
  • jp-
    5th Gear
    • Oct 2006
    • 981
    #2
    Welding stainless to mild steel is best avoided in my opinion. But I have done it with 308 wire and 100% argon. Never tried it with 75/25, so no experience there. 308 wire is a good wire for welding different stainless grades together from what I've heard.
    67 IIA 109" NADA Wagon (sold)
    • chrisste
      Low Range
      • Aug 2008
      • 8
      #3
      Thanks for the advice. I picked up some 309L wire and plan on trying that with the 75/25 mix. I'm not doing anything really serious, just applying a several plug welds to secure the replacement bulkhead assembly; then using seam sealer to make it water tight. In retrospect, I should have just purchased a replacement bulkhead!
      • chrisste
        Low Range
        • Aug 2008
        • 8
        #4
        Just an update for all to see.The plug welding went well and the bulkhead replacement assembly is in place. Yay!
ID:	170412Not pretty, but it's solid!
        • jp-
          5th Gear
          • Oct 2006
          • 981
          #5
          I don't know why this didn't occur to me, but because you were plug welding to mild steel, you would have been just fine using a mild steel wire and 75/25 I think.
          Looks like it worked fine either way.
          Working...
