Welding Stainless Steel
Welding stainless to mild steel is best avoided in my opinion. But I have done it with 308 wire and 100% argon. Never tried it with 75/25, so no experience there. 308 wire is a good wire for welding different stainless grades together from what I've heard.61 II 109" Pickup (Restomod, 350 small block, TR4050)
67 IIA 109" NADA Wagon (sold)
-I used to know everything there was to know about Land Rovers; then I joined the RN Bulletin Board. -
Thanks for the advice. I picked up some 309L wire and plan on trying that with the 75/25 mix. I'm not doing anything really serious, just applying a several plug welds to secure the replacement bulkhead assembly; then using seam sealer to make it water tight. In retrospect, I should have just purchased a replacement bulkhead!Comment
I don't know why this didn't occur to me, but because you were plug welding to mild steel, you would have been just fine using a mild steel wire and 75/25 I think.
Looks like it worked fine either way.61 II 109" Pickup (Restomod, 350 small block, TR4050)
