We usually try and leave Friday morning from Deep River and head up 395 at a relatively slow pace.
Looks like I might not be able to make it this year. There just isn't enough time in a day. :(
Is it silly to ask, what romp?
When, where, is it open?
Rob- What connections are you using the dielectric on? I use it on trailer light connections and my snowplow connections.Just wondering what else you are using it on.I've been told that "Never seize " does the same thing of promoting better connections ,anybody concure.
I normally put it on all of the spark plug wires (both ends), sometimes a thin bead around the inside edge of the distributor cap, all of the wires going to the coil, and probably unnecessary, but the fuse block of my 109 is under the hood i usually put some on the fuses too (sometimes faulty connections there due to dirt and grime cause my indicators to work intermittently). I have heard of the copper anti-seize grease working as an electric grease but have no personal experience of this. The normal silver anti-sieze does more worse than good on connections.
-Rob
I'm planning on leaving Saint John friday morning and convoy with some other rovers coming down from the maritimes.
I'm looking forward to making it down.. I haven't been in 10 years.
Hopefully it all works out.
John
