Top off!
Attachment 9623
Top off!
Attachment 9623
Replaced the clutch m/c, slave and flex pipe on my LHD SIII. I believe the appropriate phrase is 'character building'.
Master R&R was a bit of a PITA as expected.
Ugh, don't say that. It's on my to do list! Clutch M/C is a must do this spring.
Finally replaced the glass in my new window frame. I took pics of the process but for some reason, they are in a format that Mac doesn't recognize. Pictures I took with my iPhone by the way. Go figure
Finished product
Attachment 9634
The new frame sits nice and flush to the body
Attachment 9635
Compared to the old one
Attachment 9636
Not sure how that attached photo got there..
Finally got my "16mmx1.0 to 3/8" BSP" adapter re-welded and soldered so I can get my heating loop back in action. If anyone is looking for a great Radiator and ad-hoc Welding and Solder shop in Boston area, I had great luck with Natick Radiator. The owner took pride in his work, and really did a nice job getting these two different metals back together for me. It is great when you can find someone and a shop like this. No job was too small and happy to help. After a global hunt for a metric head heater offtake, I found one but also found out that the nipple was 1/2" and the Smith heater I have wants a 3/8" heater hose, and I did not find any 1/2" to 3/8" adapters out there, so back to restoring the original part that broke.
Attachment 9637
Been a good long while since I posted any progress, but this seems like a good milestone:
Attachment 9643
Welded in the new frame mounts a couple nights ago. Just needs the oil cooler assy, injectors & glowplugs, and the starter, and I should (fingers crossed) be able to fire her up for the first time.
