Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Old Man Emu shock installation
    Jul 2010
    Hurley NY
    450
    Default Old Man Emu shock installation
    So I finally bit the bullet on parabolics and new shocks.
    I'm having difficulty installing the shocks .I cant get them to clear the axle housing . The older shocks were slightly smaller in diameter and just clear the Emus are larger and dont have clearance.
    Am I missing something ? Its almost like I have to refab. the bottom spring plates shock holder back another 1'' or so ?????
    Sean
    1963 88'' IIa daily driver
    1970 88"
    1971 88"
    authenticstoneworks.com
    Feb 2007
    East Granby, CT
    1,884
    Sean-
    Do you have a picture? Are you having the same problem front & rear? I installed OME shocks on a 63 88" that I restored without any issues at all. Installed them on the Lightweight as well. Front & rear spring plates are different - the front is a little longer IIRC. Any chance you have them swapped?
    Jul 2010
    Hurley NY
    450
    Jeff,
    They are definitively the front springs.I'll get a picture up a little later.I noticed that the old ones were slightly dented from bumping the axle as well.
    Sean
    1970 88"
    1971 88"
    Feb 2007
    East Granby, CT
    1,884
    Still thinking the spring plates may not be correct. Pictures will tell.
    May 2006
    2,020
    Pix are always useful with any fitment issues.
    Thanks for the input, Jeff.
    Les Parker
    Rovers North Inc.
    Jul 2010
    Hurley NY
    450
    So I got it on but its very close is this normal.
    Sean
    1970 88"
    1971 88"
    This sounds strange. My '67 has parabolics and OME and did not have any problem with clearance or mounting. Something sounds wonky.
    Seth
    '67 IIa 109 Station Wagon (the daughter's toy)
    2003 XC70 (for the dog)
    2006 XC70 (for the wife/daughter/son)
    2002 650 Dakar (for trip planning purposes)
    Mass.
    1,796
    Almost looks like you have rear spring\shock plates on the front.
    Sep 2007
    Mystic CT,
    583
    can you post pictures of the bottom of the plate? I wonder if you have the right side up, or have the right plate on the left side or something like that
    72 SIII 88
    67 SIIA 109
    82 SIII Stage 1 V8
    Feb 2007
    East Granby, CT
    1,884
    Not normal at all. Looks like the wrong spring plates. Looks like rears used on the front. The fronts drop down at the rear and are longer, which will provide plenty of clearance between the shock and the axle housing.
    Not the best picture, but you get the idea:
