Results 1 to 8 of 8
Thread: engine block heater for petrol engines?
    Apr 2009
    Bozeman MT
    697
    Default engine block heater for petrol engines?
    Hey friends,
    We've recently moved to Montana where it's already quite cold. We've got snow on the ground and it's a lovely playground for a series rover!
    As it gets colder I'm finding it harder and harder to start my truck. In fact, I killed my battery today trying (it doesn't help that my starter is on its last legs). It made me wonder about block heaters. I know they are quite common in Diesel engines. What about for a petrol? Is it as simple as a generic on off Amazon, or should I use the diesel heater from RN? Looking forward to hearing your thoughts!
    Aug 2020
    chilliwack BC Canada
    18
    You have a plan on where the block heater will be installed?
    Apr 2009
    Bozeman MT
    697
    I think thatís part of my curiosity. A friend who specializes in restoring old Toyota FJs suggested one of the stuck on pads that warms the oil pan.
    Aug 2020
    18
    That would probably be the easiest solution. I read they work very well.
    Oct 2011
    Mountains of Western Pennsy.
    552
    I used one from my RHD Jeep, it fit into the lower radiator hose. Don't know who it was made by.
    Feb 2007
    Phippsburg, ME
    886
    Hi Nick:
    When it gets really cold your gearbox will not want to shift very easily, so something else to consider for your new, cold environment is a switch to synthetic gear oil for your gearbox, t-case, diffs and swivels. Conventional gear oils take on the consistency of rubber cement under extreme cold, while synthetics stay fluid. Pretty amazing to see: I left a bottle of each type outside overnight once when temps dropped to -30F. The synthetic flowed normally while the conventional turned into goo. And shifting even when cold is quite smooth 'n easy.
    Just my $0.02....
    Ted
    Apr 2009
    Bozeman MT
    697
    Quote Originally Posted by TedW View Post
    Hi Nick:
    Just my $0.02....
    Ted
    That's super helpful - I need to look at what's in there now. I have this strange feeling I put synthetic in last time I did it, but I but the most recent trip to the shop saw that get replaced with regular oil.
    I noticed the other day when it was -10 the engine wouldn't even turn over. The starter just clicked a very sad single time. Today, in the 30s, it turned right over. I know that's engine oil and not gear oil, it just make me appreciate how much temps play into the movement of parts.
  8. #8
    As a bit of history, Rover used to supply a 110V block heater for Series 2A models 2.25 petrol & Diesel , part number 511303 , made by Bray Heaters in UK. No longer exist I believe . If you have a screwed aluminum plug with two internal ears just above the starter motor , that's where it fitted. Its a 1 inch BSPT thread .
ID:	13501Click image for larger version.
ID:	13502Click image for larger version.
