Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: difference between 1999 D1 and 1999 D2?
    May 2007
    13
    Default difference between 1999 D1 and 1999 D2?
    hi,
    isearched the forum and could not find this answer: how can i tell an early '99 D1 from a later '99 D2? i'm looking at two '99s this weekend. thnaks in advance
    -rob
    crashed 88 RRC SWB
    May 2006
    Westford, Vermontistan
    89
    The Series II should have badge on the cargo door that reads "Series II".
    Mike Koch
    1993 Range Rover SWB
    May 2006
    2,190
    Also the door handles are the Marina style on the DI and standard car style on the DII.
    Les Parker
    Rovers North Inc.
    May 2007
    13
    Default results of road test on '99 D1 today
    D1 owners:
    took a 99 D1 for test ride; 106,000 miles, very good frame and body (located in new england). engine very quiet and smooth, accelerates very well, no noise from drivetrain, no rattles or "rotating" type noises. brakes are spongy on initial application each time brakes are used. no pull left or right under braking. road was damp but not enough to test ABS. none of the "three amigos" lit, nor any other warning lights. rear door is stuck shut.
    asking price is $5900, a little high i think, but is in very nice overall condition. CARFAX shows 3 previous owners, and there we many repairs done, though head gaaskets were not on there.
    lookiing at another '99 next week, same amount of miles. one owner, CARFAX maintenance records are not specific but vehicle was serviced regularly. price is $4900. we'll see. stay tuned for more......
    - rob
    crashed '88 RRC SWB
    Kingsport
    664
    Saw a clean '98 go for under $3k recently, $5900 is high these days.
    "Three Amigos" is a DII issue.
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
    May 2007
    13
    Quote Originally Posted by Leslie View Post
    thanks for the correction on the "three amigos".
    rover is a a dealership.....many around here are priciing them at $1000 over kelly blue book. maybe to negotiate down to its real value.....
    - rob
    crashed '88 RRC SWB
    Apr 2007
    Atlanta, GA
    55
    $5900 for a D1 or most D2's is overpriced.
    Granted, enthusiasts price down the trucks but a grand over KBB is highway robbery unless it is pristine showroom quality perfect with every single receipt and record.
    And even then I wouldn't go a nickel over $5k out the door.
    Stu
    '01 D2
    I'd call that fairly low mileage (avg ~10k a year... not bad).
    - Check under front carpets for rust.
    - When you drove it, did you try locking the CDL? Try all 4 ranges (low, high, locked, open for each of low and high)
    - What model (SD, SE, LSE)? If it has sunroofs, see if they'll let you check under the cargo area carpet for rust from the most-likely leaking sunroofs. Though that would mean opening the rear door...
    - Speaking of the rear door, has anyone tried opening it from the inside? Could help nail down the type of latch failure. I would also want to check around the rear opening for rust, if they'll let you pull the door seal around the rear opening, bottom portion. Simple to pull off and back on.
    - If that engine hasn't needed the head gasket replacement yada yada then it will need it soon. Never heard of one that didn't. Could use that to try and negotiate a few grand off the price.
    - Did all 4 electric windows work, using both the center console switches and the door switches?
    Other D1 to D2 obvious differences:
    -rear bumper looks different
    -rear lights in different places (higher on rear quarters on the D2)
    -different center portion of dash... electronic climate control, etc
    Good luck.
    99 D1
    06 LR3
    09 LR2
    Kingsport
    664
    FWIW, I'd be all over a D1 instead of a DII, because the D1 would have a CDL, whereas you'd have to get an '04 to get a CDL in a DII (unless it's been retrofited).
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
    May 2007
    13
    Quote Originally Posted by Stephen99D1 View Post
    Good luck.
    THANKS!
    the above "D1" aka "Blue 99", and another i looked at last weekend, aka "Black 99" may in fact be D2s: both had "regular" style door handles, not the flush "marina" type, but the build date of the above "mint" one is 11/98. no "Discovery II" badge on either. I couldn't open the door of Disco #2 (dealer closed). both have VIN numbers that begin with "SALTY".
    i'll have to look at some known D2s to check type of rear bumper, height of taillights.
    how do i tell if the truck has a CDL (central differential lock?)?
    i checked the VIN at the regisdtry of motor vehicles and the $5900 Blue 99 has a lein on it from a finance company, so someone owes $ on it. that could be part of the high price...
    so i am going to look at Black 99 tomorrow and take for a drive. will remember to check under carpets, check CDL if it is in fact a D1. did the D1 have the "GEMS" engine and the D2 something different?
    - rob
    crashed '88 RRC SWB
